21 years agoComponent editor advice
I have an avalon memory slave with this simple interface (export side is not listed) -- inputs from avalon:
signal address : IN STD_LOGIC_VECTOR (18 DOWNTO 1);
21 years agoI wrote:
<div class='quotetop'>QUOTE </div> --- Quote Start --- Because of another inconvenience in the "Create new component" wizard: You cant edit an already built component. Only start from scratch.... and redo the PTF etc...[/b] --- Quote End --- this is wrong. You can edit a component, as clearly stated in the component editor manual (http://www.altera.com/literature/hb/qts/qts_qii54005.pdf) where its stated... <div class='quotetop'>QUOTE </div> --- Quote Start --- To edit a component, right-click it in the list of available components, and choose Edit Component. You cannot edit components that were not created by the component editor, such as Altera®-provided components.[/b] --- Quote End --- I triede it but there seems to still be some problems with the setup and hold issue from the edited component. The edits seems not to be taken into acount in the ptf file for the system. So as far as I can see, you are still left with the manual-edit work-around suggested above. All my tests are done with quartus 4.2 sp1 and sopc 4.2. I have no experience yet with latest release 5.0.
