14 years agoComplile error on NIOS II - `onchip_ram' overflowed
Hi all
I am new in the Altera Cyclone V FPGAs and i'm doing the tutorials provided with the BEMicro SDK and i have managed to urn the image onto the chip. The problem i am having is is of the following nature. c:/altera/12.0/nios2eds/bin/gnu/h-i686-mingw32/bin/../lib/gcc/nios2-elf/4.1.2/../../../../nios2-elf/bin/ld.exe: bemicro_led_control.elf section `.text' will not fit in region `onchip_ram' c:/altera/12.0/nios2eds/bin/gnu/h-i686-mingw32/bin/../lib/gcc/nios2-elf/4.1.2/../../../../nios2-elf/bin/ld.exe: region `onchip_ram' overflowed by 19784 bytes collect2: ld returned 1 exit status make: *** [bemicro_led_control.elf] Error 1 Could you help as i am stuck on this part now. Kind regards1 Reply
The problem is quite clear: your project doesn't fit into onchip ram.
Solutions: - if your fpga has enough spare memory resource, increase onchip ram dimension, - remove any unnecessary big variables, especially strings and long arrays - avoid use of code consuming library functions, like printf and floating point management - compile in release mode instead of debug
