20 years agoCompiling under uClinux
is that possible to compile source codes under uClinux itself, i.e is there a gcc version that run under uClinux? Warm Regards11 Replies
--- Quote Start --- originally posted by mfm@Apr 19 2006, 12:11 AM <div class='quotetop'>quote--- quote end ---
--- quote start ---
you can use u-boot and tftp to download via ethernet. --- Quote End --- And if I won't use u-boot, I want to create my own tool for uploading via Ethernet, any suggestion ? Warm Regards <div align='right'><{post_snapback}> (index.php?act=findpost&pid=14476)</div> [/b] --- Quote End --- I think you'd only need U-boot (or redboot) if you wanted to upload a new kernel. If all you want to do is work with user space applications, I'd recommend using NFS. Cheers, - slacker
