20 years agoCompiling under uClinux
Hi, is that possible to compile source codes under uClinux itself, i.e is there a gcc version that run under uClinux? Warm Regards
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Hi hippo, <div class='quotetop'>QUOTE --- Quote End --- --- Quote Start --- I don't use jtag download and terminal, too. It is much faster to use ftp or nfs.[/b] --- Quote End --- How can you upload the kernel and the file system into flash memory without jtag, and without the terminal, how µClinux will start ?[/b] --- Quote End --- I wrote tools to download my custom boards. It was before jtag and IDE available. You can use u-boot and serial uart. Once setup, you don't need jtag. <div class='quotetop'>QUOTE </div> --- Quote Start --- <div class='quotetop'>QUOTE --- Quote End --- --- Quote Start --- By the ways, did you get the buildroot toolchain running on Linux[/b] --- Quote End --- Unfortunetly, NO. I get those errors all the time and I passed over 3 days trying to make it but no way! That was really disappointing especially I've really loved working under Linux, there's really tons of things to learn about. [/b] --- Quote End --- You may try Slackware (which is old and stable), or other Linux distributions. You might find somethings you like.
