20 years agoCompiling under uClinux
Hi, is that possible to compile source codes under uClinux itself, i.e is there a gcc version that run under uClinux? Warm Regards
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- Did you ever compile on a 66MHz 486 PC?[/b] --- Quote End --- Well, that's a point I have not consider, you've seen right! And talking about uCforth, is it possible to compile my old apps with ? <div class='quotetop'>QUOTE </div> --- Quote Start --- Forth had been used as firmware of Power Mac.[/b] --- Quote End --- ?????????????????????????????????????????????????????? <div class='quotetop'>QUOTE </div> --- Quote Start --- Python is ready to run. Perl has some compile errors, but can be fixed.[/b] --- Quote End --- Sorry to ask, I'm not a linux geek, but what have python and perl to do with compiling source code ? <div class='quotetop'>QUOTE </div> --- Quote Start --- Why do you want to compile program on Nios2?[/b] --- Quote End --- I want to avoid using cross compiler and emulator so I can avoid multiple errors in compilation, I want to let down the nios terminal too and communicate directly with the board via ssh and so I'll compile my apps under µClinux itself. My final goal will be to design my custom board and embed my system on(a webserver) so to be autonomous system. <div class='quotetop'>QUOTE </div> --- Quote Start --- Do you want to develop program without a PC host?[/b] --- Quote End --- How could that be done ! Is that possible? Warm Regards
