20 years agoCompiling under uClinux
Hi, is that possible to compile source codes under uClinux itself, i.e is there a gcc version that run under uClinux? Warm Regards
20 years agoHi hippo,
thanks for your reply, <div class='quotetop'>QUOTE </div> --- Quote Start --- Maybe you can try Forth instead. It is tiny and fast. Good for embeded. http://www.cs.wisc.edu/~bolo/forth.html (http://www.cs.wisc.edu/~bolo/forth.html) uCforth http://www.cvs.cx/ucforth.php (http://www.cvs.cx/ucforth.php)[/b] --- Quote End --- I've took a look and it's seemingly for ColdFire processor. <div class='quotetop'>QUOTE </div> --- Quote Start --- If you still want gcc, you should read gcc.gnu.org .[/b] --- Quote End --- Yes I want gcc cause as I see, the majority apps are to be compiled with. I read gcc.gnu.org and I can't say it's helping Warm Regards
