20 years agocompiling u-boot in nios2 ide
Has any one tried to compile u-boot in nios2 ide? It solves the problem of manually making changes to the board specific header files.
20 years agoHi shakthi,
> Has any one tried to compile u-boot in nios2 ide? It's not worth effort ... the source tree is designed to support multiple cpu architectures, variants, and boards using the CLI in a unix environment. > It solves the problem of manually making changes to the board specific header files. You don't need the IDE for this -- you need to include the Nios system header file in your u-boot tree ... and base the u-boot configuration macros on the Nios system file macros. Regards, --Scott
