21 years agoCompiling problems with uclibc ...
All, When I compile my application with uclibc, I got the following error message. <div class='quotetop'>QUOTE </div> --- Quote Start --- C:/altera/kits/nios2/bin/eclipse/plugins/com...
21 years agoThis header file is intended for kernel use only, and it mainly defines the byte order of the target machine, along with some helper functions. If I were you, I would try to remove the including of that file, put a "#define __LITTLE_ENDIAN 1234" in the same location, and give the compiler a run. If the application needs more than that, just copy them from that header file ...
