21 years agoCompiling problems with uclibc ...
All, When I compile my application with uclibc, I got the following error message. <div class='quotetop'>QUOTE </div> --- Quote Start --- C:/altera/kits/nios2/bin/eclipse/plugins/com...
21 years agowell, my recommendation is, check the source code of your application to see if <asm/byteorder.h> is being included somewhere, and try removing it if. If this doesn't remove the problem, can you post more details about the error message?
