16 years agoCompiling NIOS system in Quartus II 9.1
Hey all, New Altera user here. I generated a system in SOPC Builder. The result was a bunch of verilog files. I then proceeded to Quartus for Analysis & Synthesis. I added all the verilog ...
16 years agoSo here is what I did, I removed uclinux_nios_inst.v from my project and attempted to compile again. No errors, albeit some warnings. I set the top level entity as nios_system.v (assuming this is the name of the NIOS system which was made in SOPC Builder). I did not make an top-level verilog netlist file nor bdf file. After compilation, I used the RTL view and everything looks connected. Does this sound right, or do I need that bdf or make a top-level verilog netlist?
