22 years agoCompiling Nios II Linux Distribution v1.1
After upgrading to Quartus II 4.0 + SP1, the NIOS II core (eval version), and the NIOS II Linux distribution v1.1, I am struggling to compile the kernel for my Cyclone EP1C20. I’ve followed the quick...
22 years agoAfter applying the Windows NT patch the menuconfig worked, I changed the processor platform to the Cyclone, saved and exited.
Next problem, Build fails with the following errors <div class='quotetop'>QUOTE </div> --- Quote Start --- ------------------------------------------------ Microtronix Linux Extensions Version 1.1, Built Wed Jul 7 12:46pm EST 2004 ------------------------------------------------ make: Entering directory . //Some entries here// . /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/pio.c: In function `pio_init': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/pio.c:114: warning: passing arg 2 of `__request_region' makes integer from pointer without a cast /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/pio.c:119: warning: passing arg 2 of `__request_region' makes integer from pointer without a cast /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/pio.c: In function `pio_exit': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/pio.c:139: warning: passing arg 2 of `__release_region' makes integer from pointer without a cast /cygdrive/c/altera/kits/nios2/bin/ecli LD arch/nios2nommu/kernel/built-in.o AS arch/nios2nommu/kernel/head.o CC arch/nios2nommu/kernel/init_task.o pse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/pio.c:144: warning: passing arg 2 of `__release_region' makes integer from pointer without a cast arch/nios2nommu/kernel/.pio.o.d: done. arch/nios2nommu/kernel/.head.o.d: done. arch/nios2nommu/kernel/.init_task.o.d: done. make[2]: *** No rule to make target `arch/nios2nommu/kernel/vmlinux.lds.s', needed by `__build'. Stop. make[1]: *** [arch/nios2nommu/kernel] Error 2 make: *** [all] Error 2 make: Leaving directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'[/b] --- Quote End --- Any help, does anyone have the makefile entry or rule to make arch/nios2nommu/kernel/vmlinux.lds. Thanks again. Jan Hendrik
