20 years agoCompiling mkfs.jffs2
Hello All, I am having a little problem compiling the source code for mkfs.jffs2 in the nios 2 ide. I downloaded the source from psyent.com and everytime I try to compile the source, the IDE c...
20 years agoHi flong,
> Why dont I have to cross compile. THis program does run on NIOS right, > so doesnt that mean cross compiling? It _can_ run under uclinux -- but it's normally used on a development host to create the jffs2 file system image that gets programmed into flash. BTW: You should probably build the tool on a unix host (linux, solaris) -- under cygwin the file permissions (most notably the execute bits) don't get set. Regards, --Scott
