19 years agoCompiling Error when adding ethernet into kernel
Hi, I am going to develop ethernet applications with Nios2 and uClinux on CYCLONE_EVAL_1C12. After adding the ethernet module according to NIOSWIKI, the kernel compiling failed. Could anybo...
19 years agoPlease check your mtip port address defs in linux-2.6.x/include/nios2_system.h .
try modify the define of na_mtip_mac_control_port in setup.c. you may need to check drivers/net/Space.c and mtip1000.c. I have never tested these drivers. Please forward the patches to the wiki when you work through. It is nice to see your joint. Cheer. Hippo
