19 years agocompiler error after adding hello in user
hi hippo,
I have a new problem. Now uClinux is working well on my board (CYCLONE_1C12_EVAL). And when I adding hello.o into /romfs and burn the system into my board, It is also working well. However, when I add user applications into the /user, the compiling of kernel failed. The information is as follows: # nios2-linux-uclibc-strip --remove-section=.note --remove-section=.comment busybox /bin/sh /home/yongping/uClinux-dist/user/busybox/applets/busybox.mkll include/config.h /home/yongping/uClinux-dist/user/busybox/include/applets.h >busybox.links mkdir -p docs ( cat /home/yongping/uClinux-dist/user/busybox/docs/busybox_header.pod; /home/yongping/uClinux-dist/user/busybox/docs/autodocifier.pl /home/yongping/uClinux-dist/user/busybox/include/usage.h; cat /home/yongping/uClinux-dist/user/busybox/docs/busybox_footer.pod ) > docs/busybox.pod BusyBox Documentation mkdir -p docs pod2text docs/busybox.pod > docs/BusyBox.txt mkdir -p docs pod2man --center=BusyBox --release="version 1.00" docs/busybox.pod > docs/BusyBox.1 pod2html --noindex docs/busybox.pod > docs/busybox.net/BusyBox.html mkdir -p docs make[4]: Leaving directory `/home/yongping/uClinux-dist/user/busybox' make[3]: Leaving directory `/home/yongping/uClinux-dist/user/busybox' make[2]: Leaving directory `/home/yongping/uClinux-dist/user' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/yongping/uClinux-dist/user' make: *** [subdirs] Error 1 Could you figure it out for me? Thank you very much, Elec1 Reply
Sorry to disturb you.
I figure it out myself too. There requires a TAB space at the specified lines in Makefile. And now it is ok.
