compiler cannot find header files
I imported a folder containing one header file and several c files into the Nios II project. When I included the header file in my main task c file located outside the folder, the compiler point out the error: xx.h:No such file or directory.
Is anybody able to help me out? Thanks a lot!3 Replies
1. Path names cannot have spaces.
2. You need to include the path in the includes section of the compiler options. - Altera_Forum
Thank you for your reply. But there are still some problem in my project. I am now using Nios II EDS 9.1. I am trying to include the paths of my folders into the project, but I am not sure my operation is right. After opening 'properities', I click 'Nios II Application Paths' and add the paths of my folders to the section of 'Application include directories'. Then I build the project, and it show some errors. Like, undefined reference to 'main'. I had specified a main function in the folder but the compiler cannot detect it. What can I do to deal with the problem?
Thanks a lot! - Altera_Forum
It sounds like you're probably creating your Include paths correctly. 'Undefined reference to main' sounds more like a linker error than a compiler error. Make sure your main.c (or whatever file your main is in) compiles correctly. If it doesn't, you won't have a main.o file and the linker will fail.
