20 years agoCompiler Bug: Wrong code generation
Hi there, Recently I've ported a program from NIOS I to NIOS II. When debugging the ported program I noticed a strange problem in the code generated. Basically, the compiler generated ...
20 years ago --- Quote Start --- originally posted by svhb@Sep 21 2006, 04:11 PM no one any comment on this? it seems to be importand enough to know if it's a mistake from mrwar, or a real bug!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18394)
--- quote end ---
--- Quote End --- Yes, I can reproduce this on our NIOS2 board using the nios2-elf-g++ version 3.4.1 under Linux. I've crosschecked this with a i686-pc-linux-gnu-g++ 3.4.1. With this one, the generated code runs correctly and also a fast search in the gcc bugzilla didn't come up with a matching bugreport, so it seems like this is a nios2-port specific bug. @mrwar: Did you already forward this to Altera support? Regards, Andreas
