20 years agoCompile using SOPC builder for uclinux host
Hi all,
To compile a library project, I use SOPC Builder. I have the configure file, Assuming that the pwd is the configure file directory, which contains two subdirectories of source and headers respectively. so I write under the shell command line: ./configure --target=nios2-elf-gcc --host=uclinux How can I modify the file config.sub to take into account uclinux for the basic_machine=nios2?????????? Best regards http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gifNo RepliesBe the first to reply
