16 years agoCompile problem with CompactFlash
I have updated my uClinux installation. I'm trying to compile a project with CF support. I followed the instructions in the Wiki page, but when I try to compile it I get: make ln -sf staging-pkg-config tools/nios2-linux-uclibc-pkg-config rm -f /home/horacio/nios2-linux/uClinux-dist/linux-2.6.x/usr/initramfs_data.cpio.gz make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/horacio/nios2-linux/uClinux-dist/../linux-2.6 O=/home/horacio/nios2-linux/uClinux-dist/linux-2.6.x -j8 zImage || exit 1 make[1]: Entering directory `/home/horacio/nios2-linux/linux-2.6' no emulation specific options. CHK include/asm-nios2/nios2.h perl -I/home/horacio/nios2-linux/linux-2.6/arch/nios2/scripts /home/horacio/nios2-linux/linux-2.6/arch/nios2/scripts/gen_nios2.h.pl cpu ddr_sdram_0 < /home/horacio/nios2-linux/MyAlteraFiles/StratixII_CF/NiosII_stratixII_2s60_RoHS_standard_sopc.ptf > include/asm-nios2/nios2.h.tmp; if [ -r include/asm-nios2/nios2.h ] && cmp -s include/asm-nios2/nios2.h include/asm-nios2/nios2.h.tmp; then rm -f include/asm-nios2/nios2.h.tmp; else echo ' UPD include/asm-nios2/nios2.h'; mv -f include/asm-nios2/nios2.h.tmp include/asm-nios2/nios2.h; fi GEN /home/horacio/nios2-linux/uClinux-dist/linux-2.6.x/Makefile CHK include/linux/version.h CHK include/linux/utsrelease.h SYMLINK include/asm -> include/asm-nios2 Using /home/horacio/nios2-linux/linux-2.6 as source for kernel CALL /home/horacio/nios2-linux/linux-2.6/scripts/checksyscalls.sh CHK include/linux/compile.h GEN usr/initramfs_data.cpio.gz AS usr/initramfs_data.gz.o LD usr/built-in.o LD vmlinux.o MODPOST vmlinux.o WARNING: modpost: Found 2 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISMATCH=y' GEN .version CHK include/linux/compile.h UPD include/linux/compile.h CC init/version.o LD init/built-in.o LD vmlinux __pata_platform_remove: discarded in section `.devexit.text' from drivers/built-in.o make[2]: *** [vmlinux] Error 1 make[1]: *** [sub-make] Error 2 make[1]: Leaving directory `/home/horacio/nios2-linux/linux-2.6' make: *** [linux] Error 1 Thanks for any helpNo RepliesBe the first to reply
