16 years agoCompile Android to nios2
hello, I must bring s.o. Android on the Cyclone FPGA 2. You can do this? If so, how? thank you
16 years ago --- Quote Start --- AFAIK, there are Android ports for X86 (for ATOM based devices). So the basic Android sources should be not too much tied to the ARM. OTOH ARM is a lot more similar to NIOS than X86 is, so using an ARM port as a basis seems appropriate. -Michael --- Quote End --- thanks, and how do I implement ARM on the Cyclone 2?
