21 years agoCompilation errors
I got compilation error on default configuration.
/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c: In function `init_hwif_default': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c:262: error: `na_ide_ide' undeclared (first use in this function) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c:262: error: (Each undeclared identifier is reported only once /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c:262: error: for each function it appears in.) /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c: In function `init_ide_data': /cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/drivers/ide/ide.c:313: error: `na_ide_ide_irq' Please, help.2 Replies
You need to remove IDE support from your kernel configuration. It can be found at:
Device Drivers ---> ATA/ATAPI/MFM/RLL support ---> < > ATA/ATAPI/MFM/RLL support Dennis Scott Microtronix Datacom - Altera_Forum
