9 years agoCompilation Error
Dear All, I'm trying to build a very basic system on Altera's DE2 board and following the correct procedure as specified by the provided tutorial, but for the last two days, I'm just stuck in t...
9 years agoOkay here is the update.. I just increased the amount of On-Chip memory from 4096 bytes to around 20K bytes and it just solved the problem. But I was really surprised that how can a simple 'Hello Word' program occupies that much memory, may be invisible code behind the scene is the reason :-P anyways then I started facing another issue of program downloading into the FPGA board (NIOS II IDE for Eclipse) which luckily got solved.
So thank you sstrell and TCWORLD for your kind cooperation.
