10 years agocompiation of altera bare metal failed with g++ not found
I'm a bit frustrated with the soceds tool. even I tried to compile the examples in the altera installation folder, it pop up some strange tool chain issues like g++ not found . Any one know how to fi...
10 years ago@J_FHMS, you need to use the Embedded Command Shell script/file and then run "eclipse" inside that shell. The shell gives environment variables like which compiler to use when building the HWLIB examples.
