21 years agocompactflash test
I use the compactflash test code on the forum the main function first calls " IDE_initialize()" but when the programme run to "/* Enable IDE interrupts */ alt_irq_register(ide_irq, ...
21 years agonow ,i am using the code in the "Tested IP" area of this forum
execute the code , phenomenon above appears the problem maybe come along the "idetarphandler" and i find ,the compactflash core or other things only back up ASCII code or appears confused code.
