21 years agocompactflash test
I use the compactflash test code on the forum the main function first calls " IDE_initialize()" but when the programme run to "/* Enable IDE interrupts */ alt_irq_register(ide_irq, ...
21 years agoHello,
The CF core from 5.0 should work with other versions of Quartus, there is nothing very special about it. However, you will need to carefully assign pins and ensure that the electrical interface to the card is correct. There is some test software you can download in the "Tested IP" area of this forum. This includes CF test/diagnostic software (runs without OS) and some hardware example designs for Altera Nios development boards.
