17 years agoCompactFlash support
Hi all, I try to put in operation the CompactFlash in my development kit, but during the compilation of uClinux source I have this errors : ......................................................
17 years agoHi all,
Here is the error message when compiling : CC drivers/ata/libata-core.o drivers/ata/libata-core.c: In function `ata_devchk': drivers/ata/libata-core.c:640: error: implicit declaration of function `iowrite8' drivers/ata/libata-core.c:649: error: implicit declaration of function `ioread8' drivers/ata/libata-core.c: In function `ata_sg_setup_one': drivers/ata/libata-core.c:4329: warning: use of cast expressions as lvalues is deprecated drivers/ata/libata-core.c:4353: warning: use of cast expressions as lvalues is deprecated drivers/ata/libata-core.c: In function `ata_sg_setup': drivers/ata/libata-core.c:4412: warning: use of cast expressions as lvalues is deprecated drivers/ata/libata-core.c: In function `ata_data_xfer': drivers/ata/libata-core.c:4490: error: implicit declaration of function `iowrite16_rep' drivers/ata/libata-core.c:4492: error: implicit declaration of function `ioread16_rep' drivers/ata/libata-core.c:4501: error: implicit declaration of function `iowrite16' drivers/ata/libata-core.c:4503: error: implicit declaration of function `ioread16' drivers/ata/libata-core.c: In function `ata_wait_register': drivers/ata/libata-core.c:6816: error: implicit declaration of function `ioread32' make[4]: *** [drivers/ata/libata-core.o] Erreur 1 make[3]: *** [drivers/ata] Erreur 2 Should defined ioread8, ioread16 ... in asm/io.h? # define ioread8(X) readb(X)# define ioread16(X) readw(X) ... What is the kernel configuration for the compact flash? I followed the instructions given in nioswiki : http://www.nioswiki.com/operatingsystems/u...ux/compactflash (http://www.nioswiki.com/operatingsystems/uclinux/compactflash) Thanks,
