20 years agoCompactFlash Problem
I'm a newbie in Nios uClinux , I use Stratix 1s40 board ,when I want mount Fat Filesystem but have some truble. At first time i mount Fat Filesystem CF card have error like this:
# /bin/mount -t vfat /dev/hda1 /mnt/ide0 -n hda: hda1 FAT: codepage cp437 not found hda: hda1 mount: wrong fs type, bad option, bad superblock on /dev/hda1, or too many mounted file systems and then i find this topic : http://www.niosforum.com/forum/index.php?s...pic=2518&hl=437 (http://www.niosforum.com/forum/index.php?showtopic=2518&hl=437) in this topic have trouble like me so i follow those steps to enable Code 437 (United States & Canada) but the problem was not solved, when i rebuild kernel and upload to my board Stratix 1s40 and run it ,I got an another problem happen like this: # mount -t vfat /dev/hda1 /mnt/ide0 -n mount -t vfat /dev/hda1 /mnt/ide0 -n hda: hda1 FAT: IO charset iso8859-1 not found hda: hda1 mount: wrong fs type, bad option, bad superblock on /dev/hda1, or too many mounted file systems i'm sure when i use Extended 2 Filesystem in CF card i can mount it , but when i use Fat filesystem i can't mount it anymore. have anyone can help me solve this problem? let me can mount Fat filesystem cf card in my Nios Board. Thanks!(Sorry my English is not so good><)2 Replies
Hi
I beleive you have to enable support for that character set in the kernel as well. I'm not exacly sure where, but its not hard to find. Good luck - Altera_Forum
Thank you for your recommend!
It work! thanks!
