19 years agocompact flash
I'm designing a target board using a nios2 with compact flash as the IDE hard-drive. I've looked at the schematic for the compact flash hardware on the Stratix II DSP kit to more or less copy...
19 years agoWhen I wrote,
"there are no bus-timing parameters exposed when the component is instantiated." I did not realise that it is possible to edit the class.ptf file associated with the component in SOPC Builder. Hitherto, I had assumed that if you needed to tune up an SOPC Builder component you had to use a parameter statement in the Verilog. stebla
