19 years agocompact flash
I'm designing a target board using a nios2 with compact flash as the IDE hard-drive. I've looked at the schematic for the compact flash hardware on the Stratix II DSP kit to more or less copy...
19 years agoHi Banx,
I'm using Altera's cf component in SOPC Builder, and there are no bus-timing parameters exposed when the component is instantiated. Presumably, this means that I may hit the timing problem with larger cards in the future? Another thing is puzzling me, I don't understand why one needs to be able to switch power to the cf card if it is always to be used in true IDE mode? The Altera DSP kit uses a power mosfet and you have explained that you use a switchable 3.3V regulator driven from 5V. The cf spec says that a cf card samples the atasel# line on pin 9 on the transition from power off to power on; if atasel# is low the cf card is in IDE mode. I'm only using my cf card to be an IDE disc for my system, so I reasoned that I ought to be able to throw out the mosfet/switchable regulator on the target board that I'm designing and just permanently connect the cf card to Vcc=3.3V. However, I've just done a test on my DSP kit by forcing the cf power to be always on by going, assign cf_power=1'b1 assign cf_atasel=1'b0;//Forced atasel low after reading Nios II 6.0 errata.pdf and the Nios II IDE cf example that shipped with the DSP kit (essentially Jesse's software I think) says that it cannot initialize the cf. However, if I allow the cf_power signal free to toggle, the cf card works. stebla
