20 years agoCompact Flash
I'm using a 1GByte Compact Flash disk with the Altera 1c20 eval board. I can not write more than 500MBytes to it. Does anybody know how to solve this problem?
20 years ago --- Quote Start --- originally posted by nacide@Oct 6 2006, 05:39 AM it is possible to switch off the leds and 7 seg display when configuring the kernel.
processor type and features
[] enable leds, seven segment display
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18576)
--- quote end ---
--- Quote End --- After performing those commands, I had to reformat the disk. Now, I'm able to write more than 512MB. It seems that I missed up the Disk, when I turned the card off before umounting the disk. Why is that? In my application, the power can go away while the board is running. Is there a way out of this?? There must be a task running in the background to blink the leds, and the seven segment displays. Is this standard with the uClinux-Nios port? Thanks
