21 years agocompact flash problem
Hi, I'm working on the nios II cyclone board card.But I need to suppress the cf interface.So I did it in SOPC builder. Then I need to implement linux in the nios board card.So I configure...
21 years agoHi Wentao,
Here is the kernel booting message: "Welcome to Altera SOPC Builder Version 4.20, Built Tue Nov 2 09:42:35 PST 2004 Welcome to the Nios II Development Kit Version 1.1, Built Wed Nov 24 20:13:46 PSt 2004 Example designs can be found in \cygdrive\c\altera\kits\nios2\examples <Executing user startup script: c:/altera/kits/nios2/user.bashrc Microtronix Linux Extensions Version 1.3, Built December 30th 2004 \cygdrive\c\altera\kits\nios2\examples [SOPC Builder]$ nios2-terminal nios2-terminal: connected to hardware targetusing JTAG nios2-terminal: UART on cable nios2-terminal: "ByteBlasterII [LPT1], device 1, instance 0 nios2-terminal: Warning: The JTAG cable you are usingis not suported for Nios II systems. You may experience intermittent JTAG communication failures with this cable. Please use a USB Blaster revision B cable or another supported cable. Please refer to the file errata.txt included in the Nios II development kit documents directory for more information. nios2-terminal: starting in terminal mode<Control-C exits> " And it stops, wheareas when it works I've exactly the same message but after the last ligne, it starts linux.
