20 years agoCompact Flash HW & SW Examples
Hi all, I found this site: http://www.niosforum.com/pages/project_det...p_id=67&t_id=17 (http://www.niosforum.com/pages/project_details.php?p_id=67&t_id=17) and downloaded the the design fi...
20 years ago --- Quote Start --- originally posted by hippo+jun 19 2006, 08:41 am--><div class='quotetop'>quote (hippo @ jun 19 2006, 08:41 am)</div>
--- quote start ---
<!--quotebegin-viethoang@Jun 15 2006, 05:07 PM hi hippo,
thank you very much for your help. i am just a beginner.
i have fixed that problem.
but i have another question.
as your instruction:
--- quote end ---
--- quote start ---
you need os support. there ucos/2, ecos, and uclinux.
i prefer uclinux.
http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux) --- Quote End --- I downloaded zImage for 2C35 board: zimage_std_2c35. And then I downloaded this image to 2C35 board (ofcourse, after download .sof for it). This process finished successfully. But when I ran nios2-terminal there's no response from the board, the Nios II Command Shell only displayed: [sopc builder]$ nios2-terminal --cable usb-blaster
nios2-terminal: connected to hardware target using jtag uart on cable
nios2-terminal: "usb-blaster [usb-0]", device 1, instance 0
nios2-terminal: (use the ide stop button or ctrl-c to terminate) and did not return. What is this error? How can I solve it? Thanks. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16193)</div> [/b] --- Quote End --- did you use this sof ? altera/kits/nios2_60/examples/verilog/niosII_cycloneII_2c35/standard/standard.sof Please post it over uclinux forum. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16238)</div> [/b] --- Quote End --- Hi Hippo, Thanks for your answer. Yes, I used that .sof file. I don't know what happened. Do you have any idea? Thanks.
