20 years agoCompact Flash HW & SW Examples
Hi all, I found this site: http://www.niosforum.com/pages/project_det...p_id=67&t_id=17 (http://www.niosforum.com/pages/project_details.php?p_id=67&t_id=17) and downloaded the the design fi...
20 years agoHi hippo,
Thank you very much for your help. I am just a beginner. I have fixed that problem. But I have another question. As your instruction: <div class='quotetop'>QUOTE </div> --- Quote Start --- You need OS support. There uCOS/2, eCos, and uClinux. I prefer uClinux. http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux)[/b] --- Quote End --- I downloaded zImage for 2C35 board: zimage_std_2c35. And then I downloaded this image to 2C35 board (ofcourse, after download .sof for it). This process finished successfully. But when I ran nios2-terminal there's no response from the board, the Nios II Command Shell only displayed: [sopc builder]$ nios2-terminal --cable usb-blasternios2-terminal: connected to hardware target using jtag uart on cable
nios2-terminal: "usb-blaster [usb-0]", device 1, instance 0
nios2-terminal: (use the ide stop button or ctrl-c to terminate) and did not return. What is this error? How can I solve it? Thanks.
