21 years ago
Compact Flash Card problem
I am trying to implemnent the CF Card in my Nios system.
But there is not any reference about it.
Should I write a driver for it and prepare the subroutine? or there is already one?
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif Thanks a lot!!
    To Kerri, Joe90 and Anagnost,
    -Have you been able to compile successfully the CFcomponent zip file&#39;s project "cf_ide_test"?
    I tried it for 1S40fullfeatured using NIOSII V1.01 but got compile errors (see below); did you have to modify any code (eg# define CF_IDE_BASE , "cf",....) and which version of NIOSII you used? maybe V1.01 is too new?)
    -besides this test, does ALtera have any other test to verify the inserted CFcard works or not?
    The "board_diag" project in the installation only test the onboard flash chip, not the CFcard
    Thanks # ####################################################
    Error *** [obj/ideutils.o] Error 1 cf_ide_test_0_1s40
    Error # error This IDE utility requires a CompactFlash Interface component named "cf" ideutils.c cf_ide_test_0_1s40 line 16
    Error altera_avalon_cf_regs.h: No such file or directory ideutils.c cf_ide_test_0_1s40 line 29
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 78
    Error error: (Each undeclared identifier is reported only once ideutils.c cf_ide_test_0_1s40 line 78
    Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_STATUS&#39; ideutils.c cf_ide_test_0_1s40 line 78
    Error error: `CF_CTL_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 86
    Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_CTL_STATUS&#39; ideutils.c cf_ide_test_0_1s40 line 86
    Error error: `ALTERA_AVALON_CF_CTL_STATUS_PRESENT_MSK&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 87
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 120
    Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_ALTERNATE_STATUS&#39; ideutils.c cf_ide_test_0_1s40 line 120
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 150
    Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_ERROR&#39; ideutils.c cf_ide_test_0_1s40 line 165
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 195
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 216
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 237
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 257
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 289
    Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_DEVICE_HEAD&#39; ideutils.c cf_ide_test_0_1s40 line 289
    Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_DEVICE_CONTROL&#39; ideutils.c cf_ide_test_0_1s40 line 293
    Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_SECTOR_COUNT&#39; ideutils.c cf_ide_test_0_1s40 line 378
    Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_SECTOR_NUMBER&#39; ideutils.c cf_ide_test_0_1s40 line 379
    Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_CYLINDER_LOW&#39; ideutils.c cf_ide_test_0_1s40 line 380
    Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_CYLINDER_HIGH&#39; ideutils.c cf_ide_test_0_1s40 line 381
    Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_DEVICE_HEAD&#39; ideutils.c cf_ide_test_0_1s40 line 382
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 415
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 495
    Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_DATA&#39; ideutils.c cf_ide_test_0_1s40 line 513
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 556
    Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_SECTOR_COUNT&#39; ideutils.c cf_ide_test_0_1s40 line 556
    Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_SECTOR_NUMBER&#39; ideutils.c cf_ide_test_0_1s40 line 557
    Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_CYLINDER_LOW&#39; ideutils.c cf_ide_test_0_1s40 line 558
    Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_CYLINDER_HIGH&#39; ideutils.c cf_ide_test_0_1s40 line 559
    Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_COMMAND&#39; ideutils.c cf_ide_test_0_1s40 line 566
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 591
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 632
    Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_DATA&#39; ideutils.c cf_ide_test_0_1s40 line 670
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 810
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 970
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1080
    Error error: `CF_CTL_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1216
    Error error: `ALTERA_AVALON_CF_CTL_STATUS_PRESENT_MSK&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1217
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1242
    Error error: `ALTERA_AVALON_CF_CTL_STATUS_POWER_MSK&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1943
    Error error: `CF_CTL_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1943
    Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_CTL_CONTROL&#39; ideutils.c cf_ide_test_0_1s40 line 1943
    Error error: `CF_IDE_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1954
    Error error: `CF_CTL_IRQ&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1977
    Error error: `ALTERA_AVALON_CF_CTL_STATUS_IRQ_EN_MSK&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1979
    Error error: `CF_IDE_IRQ&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1982
    Error error: `ALTERA_AVALON_CF_IDE_CTL_IRQ_EN_MSK&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1983
    Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_CTL&#39; ideutils.c cf_ide_test_0_1s40 line 1983
    Error error: `CF_CTL_BASE&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1999
    Error error: `CF_IDE_IRQ&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 2002
    Error error: `CF_CTL_IRQ&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 2003
    --- Quote Start ---
    originally posted by niosfan@Jan 6 2005, 04:25 PM
    to kerri, joe90 and anagnost,
    -have you been able to compile successfully the cfcomponent zip file&#39;s project "cf_ide_test"?
    i tried it for 1s40fullfeatured using niosii v1.01 but got compile errors (see below); did you have to modify any code (eg# define cf_ide_base , "cf",....) and which version of niosii you used? maybe v1.01 is too new?)
    -besides this test, does altera have any other test to verify the inserted cfcard works or not?
    the "board_diag" project in the installation only test the onboard flash chip, not the cfcard
    thanks # ####################################################
    error *** [obj/ideutils.o] error 1 cf_ide_test_0_1s40
    error # error this ide utility requires a compactflash interface component named "cf" ideutils.c cf_ide_test_0_1s40 line 16
    error altera_avalon_cf_regs.h: no such file or directory ideutils.c cf_ide_test_0_1s40 line 29
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 78
    error error: (each undeclared identifier is reported only once ideutils.c cf_ide_test_0_1s40 line 78
    warning implicit declaration of function `iord_altera_avalon_cf_ide_status&#39; ideutils.c cf_ide_test_0_1s40 line 78
    error error: `cf_ctl_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 86
    warning implicit declaration of function `iord_altera_avalon_cf_ctl_status&#39; ideutils.c cf_ide_test_0_1s40 line 86
    error error: `altera_avalon_cf_ctl_status_present_msk&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 87
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 120
    warning implicit declaration of function `iord_altera_avalon_cf_ide_alternate_status&#39; ideutils.c cf_ide_test_0_1s40 line 120
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 150
    warning implicit declaration of function `iord_altera_avalon_cf_ide_error&#39; ideutils.c cf_ide_test_0_1s40 line 165
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 195
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 216
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 237
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 257
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 289
    warning implicit declaration of function `iowr_altera_avalon_cf_ide_device_head&#39; ideutils.c cf_ide_test_0_1s40 line 289
    warning implicit declaration of function `iowr_altera_avalon_cf_ide_device_control&#39; ideutils.c cf_ide_test_0_1s40 line 293
    warning implicit declaration of function `iord_altera_avalon_cf_ide_sector_count&#39; ideutils.c cf_ide_test_0_1s40 line 378
    warning implicit declaration of function `iord_altera_avalon_cf_ide_sector_number&#39; ideutils.c cf_ide_test_0_1s40 line 379
    warning implicit declaration of function `iord_altera_avalon_cf_ide_cylinder_low&#39; ideutils.c cf_ide_test_0_1s40 line 380
    warning implicit declaration of function `iord_altera_avalon_cf_ide_cylinder_high&#39; ideutils.c cf_ide_test_0_1s40 line 381
    warning implicit declaration of function `iord_altera_avalon_cf_ide_device_head&#39; ideutils.c cf_ide_test_0_1s40 line 382
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 415
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 495
    warning implicit declaration of function `iord_altera_avalon_cf_ide_data&#39; ideutils.c cf_ide_test_0_1s40 line 513
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 556
    warning implicit declaration of function `iowr_altera_avalon_cf_ide_sector_count&#39; ideutils.c cf_ide_test_0_1s40 line 556
    warning implicit declaration of function `iowr_altera_avalon_cf_ide_sector_number&#39; ideutils.c cf_ide_test_0_1s40 line 557
    warning implicit declaration of function `iowr_altera_avalon_cf_ide_cylinder_low&#39; ideutils.c cf_ide_test_0_1s40 line 558
    warning implicit declaration of function `iowr_altera_avalon_cf_ide_cylinder_high&#39; ideutils.c cf_ide_test_0_1s40 line 559
    warning implicit declaration of function `iowr_altera_avalon_cf_ide_command&#39; ideutils.c cf_ide_test_0_1s40 line 566
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 591
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 632
    warning implicit declaration of function `iowr_altera_avalon_cf_ide_data&#39; ideutils.c cf_ide_test_0_1s40 line 670
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 810
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 970
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1080
    error error: `cf_ctl_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1216
    error error: `altera_avalon_cf_ctl_status_present_msk&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1217
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1242
    error error: `altera_avalon_cf_ctl_status_power_msk&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1943
    error error: `cf_ctl_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1943
    warning implicit declaration of function `iowr_altera_avalon_cf_ctl_control&#39; ideutils.c cf_ide_test_0_1s40 line 1943
    error error: `cf_ide_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1954
    error error: `cf_ctl_irq&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1977
    error error: `altera_avalon_cf_ctl_status_irq_en_msk&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1979
    error error: `cf_ide_irq&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1982
    error error: `altera_avalon_cf_ide_ctl_irq_en_msk&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1983
    warning implicit declaration of function `iowr_altera_avalon_cf_ide_ctl&#39; ideutils.c cf_ide_test_0_1s40 line 1983
    error error: `cf_ctl_base&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1999
    error error: `cf_ide_irq&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 2002
    error error: `cf_ctl_irq&#39; undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 2003
    --- Quote End ---
    hi
    you have to change the name
    for example
    you compactflash card name is cf_0
    you should change "cf_ide_irq" to "cf_0_ide_irq"
