22 years agoCompact Flash Card problem
I am trying to implemnent the CF Card in my Nios system. But there is not any reference about it. Should I write a driver for it and prepare the subroutine? or there is already one? http:...
21 years ago --- Quote Start --- originally posted by niosfan@Jan 6 2005, 04:25 PM to kerri, joe90 and anagnost,
-have you been able to compile successfully the cfcomponent zip file's project "cf_ide_test"?
i tried it for 1s40fullfeatured using niosii v1.01 but got compile errors (see below); did you have to modify any code (eg# define cf_ide_base , "cf",....) and which version of niosii you used? maybe v1.01 is too new?)
-besides this test, does altera have any other test to verify the inserted cfcard works or not?
the "board_diag" project in the installation only test the onboard flash chip, not the cfcard
thanks # ####################################################
error *** [obj/ideutils.o] error 1 cf_ide_test_0_1s40
error # error this ide utility requires a compactflash interface component named "cf" ideutils.c cf_ide_test_0_1s40 line 16
error altera_avalon_cf_regs.h: no such file or directory ideutils.c cf_ide_test_0_1s40 line 29
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 78
error error: (each undeclared identifier is reported only once ideutils.c cf_ide_test_0_1s40 line 78
warning implicit declaration of function `iord_altera_avalon_cf_ide_status' ideutils.c cf_ide_test_0_1s40 line 78
error error: `cf_ctl_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 86
warning implicit declaration of function `iord_altera_avalon_cf_ctl_status' ideutils.c cf_ide_test_0_1s40 line 86
error error: `altera_avalon_cf_ctl_status_present_msk' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 87
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 120
warning implicit declaration of function `iord_altera_avalon_cf_ide_alternate_status' ideutils.c cf_ide_test_0_1s40 line 120
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 150
warning implicit declaration of function `iord_altera_avalon_cf_ide_error' ideutils.c cf_ide_test_0_1s40 line 165
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 195
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 216
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 237
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 257
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 289
warning implicit declaration of function `iowr_altera_avalon_cf_ide_device_head' ideutils.c cf_ide_test_0_1s40 line 289
warning implicit declaration of function `iowr_altera_avalon_cf_ide_device_control' ideutils.c cf_ide_test_0_1s40 line 293
warning implicit declaration of function `iord_altera_avalon_cf_ide_sector_count' ideutils.c cf_ide_test_0_1s40 line 378
warning implicit declaration of function `iord_altera_avalon_cf_ide_sector_number' ideutils.c cf_ide_test_0_1s40 line 379
warning implicit declaration of function `iord_altera_avalon_cf_ide_cylinder_low' ideutils.c cf_ide_test_0_1s40 line 380
warning implicit declaration of function `iord_altera_avalon_cf_ide_cylinder_high' ideutils.c cf_ide_test_0_1s40 line 381
warning implicit declaration of function `iord_altera_avalon_cf_ide_device_head' ideutils.c cf_ide_test_0_1s40 line 382
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 415
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 495
warning implicit declaration of function `iord_altera_avalon_cf_ide_data' ideutils.c cf_ide_test_0_1s40 line 513
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 556
warning implicit declaration of function `iowr_altera_avalon_cf_ide_sector_count' ideutils.c cf_ide_test_0_1s40 line 556
warning implicit declaration of function `iowr_altera_avalon_cf_ide_sector_number' ideutils.c cf_ide_test_0_1s40 line 557
warning implicit declaration of function `iowr_altera_avalon_cf_ide_cylinder_low' ideutils.c cf_ide_test_0_1s40 line 558
warning implicit declaration of function `iowr_altera_avalon_cf_ide_cylinder_high' ideutils.c cf_ide_test_0_1s40 line 559
warning implicit declaration of function `iowr_altera_avalon_cf_ide_command' ideutils.c cf_ide_test_0_1s40 line 566
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 591
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 632
warning implicit declaration of function `iowr_altera_avalon_cf_ide_data' ideutils.c cf_ide_test_0_1s40 line 670
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 810
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 970
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1080
error error: `cf_ctl_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1216
error error: `altera_avalon_cf_ctl_status_present_msk' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1217
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1242
error error: `altera_avalon_cf_ctl_status_power_msk' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1943
error error: `cf_ctl_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1943
warning implicit declaration of function `iowr_altera_avalon_cf_ctl_control' ideutils.c cf_ide_test_0_1s40 line 1943
error error: `cf_ide_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1954
error error: `cf_ctl_irq' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1977
error error: `altera_avalon_cf_ctl_status_irq_en_msk' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1979
error error: `cf_ide_irq' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1982
error error: `altera_avalon_cf_ide_ctl_irq_en_msk' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1983
warning implicit declaration of function `iowr_altera_avalon_cf_ide_ctl' ideutils.c cf_ide_test_0_1s40 line 1983
error error: `cf_ctl_base' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1999
error error: `cf_ide_irq' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 2002
error error: `cf_ctl_irq' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 2003 --- Quote End --- hi you have to change the name for example you compactflash card name is cf_0 you should change "cf_ide_irq" to "cf_0_ide_irq"
