To Kerri, Joe90 and Anagnost,
-Have you been able to compile successfully the CFcomponent zip file's project "cf_ide_test"?
I tried it for 1S40fullfeatured using NIOSII V1.01 but got compile errors (see below); did you have to modify any code (eg# define CF_IDE_BASE , "cf",....) and which version of NIOSII you used? maybe V1.01 is too new?)
-besides this test, does ALtera have any other test to verify the inserted CFcard works or not?
The "board_diag" project in the installation only test the onboard flash chip, not the CFcard
Thanks # ####################################################
Error *** [obj/ideutils.o] Error 1 cf_ide_test_0_1s40
Error # error This IDE utility requires a CompactFlash Interface component named "cf" ideutils.c cf_ide_test_0_1s40 line 16
Error altera_avalon_cf_regs.h: No such file or directory ideutils.c cf_ide_test_0_1s40 line 29
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 78
Error error: (Each undeclared identifier is reported only once ideutils.c cf_ide_test_0_1s40 line 78
Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_STATUS' ideutils.c cf_ide_test_0_1s40 line 78
Error error: `CF_CTL_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 86
Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_CTL_STATUS' ideutils.c cf_ide_test_0_1s40 line 86
Error error: `ALTERA_AVALON_CF_CTL_STATUS_PRESENT_MSK' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 87
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 120
Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_ALTERNATE_STATUS' ideutils.c cf_ide_test_0_1s40 line 120
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 150
Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_ERROR' ideutils.c cf_ide_test_0_1s40 line 165
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 195
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 216
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 237
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 257
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 289
Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_DEVICE_HEAD' ideutils.c cf_ide_test_0_1s40 line 289
Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_DEVICE_CONTROL' ideutils.c cf_ide_test_0_1s40 line 293
Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_SECTOR_COUNT' ideutils.c cf_ide_test_0_1s40 line 378
Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_SECTOR_NUMBER' ideutils.c cf_ide_test_0_1s40 line 379
Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_CYLINDER_LOW' ideutils.c cf_ide_test_0_1s40 line 380
Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_CYLINDER_HIGH' ideutils.c cf_ide_test_0_1s40 line 381
Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_DEVICE_HEAD' ideutils.c cf_ide_test_0_1s40 line 382
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 415
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 495
Warning implicit declaration of function `IORD_ALTERA_AVALON_CF_IDE_DATA' ideutils.c cf_ide_test_0_1s40 line 513
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 556
Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_SECTOR_COUNT' ideutils.c cf_ide_test_0_1s40 line 556
Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_SECTOR_NUMBER' ideutils.c cf_ide_test_0_1s40 line 557
Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_CYLINDER_LOW' ideutils.c cf_ide_test_0_1s40 line 558
Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_CYLINDER_HIGH' ideutils.c cf_ide_test_0_1s40 line 559
Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_COMMAND' ideutils.c cf_ide_test_0_1s40 line 566
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 591
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 632
Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_DATA' ideutils.c cf_ide_test_0_1s40 line 670
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 810
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 970
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1080
Error error: `CF_CTL_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1216
Error error: `ALTERA_AVALON_CF_CTL_STATUS_PRESENT_MSK' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1217
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1242
Error error: `ALTERA_AVALON_CF_CTL_STATUS_POWER_MSK' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1943
Error error: `CF_CTL_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1943
Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_CTL_CONTROL' ideutils.c cf_ide_test_0_1s40 line 1943
Error error: `CF_IDE_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1954
Error error: `CF_CTL_IRQ' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1977
Error error: `ALTERA_AVALON_CF_CTL_STATUS_IRQ_EN_MSK' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1979
Error error: `CF_IDE_IRQ' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1982
Error error: `ALTERA_AVALON_CF_IDE_CTL_IRQ_EN_MSK' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1983
Warning implicit declaration of function `IOWR_ALTERA_AVALON_CF_IDE_CTL' ideutils.c cf_ide_test_0_1s40 line 1983
Error error: `CF_CTL_BASE' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 1999
Error error: `CF_IDE_IRQ' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 2002
Error error: `CF_CTL_IRQ' undeclared (first use in this function) ideutils.c cf_ide_test_0_1s40 line 2003
