21 years ago
Communication between SL811 and NIOS
did anybody knows what this errors means????
# usb 1-1: new low speed USB device using address 4
usb 1-1: control timeout on ep0out
usb 1-1: device not accepting address 4, error -110
usb 1-1: new low speed USB device using address 5
usb 1-1: device not accepting address 5, error -108
i'm using the sl811hs
i still can not make it comunicate well... could anybody help me...
Jimmy
    u can see the error code in include/asm-generic/errno.h
    then in documentation/usb/error-codes.txt to see the causation of the error. 110 means timeout.
    by the way,
    how many setup/wait/hold cycles while you setting the sl811 scheduling as user logic???
    thanks,
    well... in the setup i have 2ns,
    in wait 65ns
    and in hold 5ns...
    based on the cypress application note about the interfacing with external processors...
    how you define your avalon slave addressing... as a memory or as a register
    jimmy
    as register,
    i use altera cyclone board,and want to add usb interface.
    so it's too much problems.
    can you give me your usb interface module??
    [email protected]
    thanks!!!
