20 years agocommunicate uart with VB
sorry, my english is poor. I transmit a wavfile to Nios II within MSCOMM32.OCX baud rate=115200 bps data bit=8 parity bit=none stop bit=1 RECEIVER in Nios II IDE alt_16 bu...
20 years agoif the uart buffer is overloaded then data will get lost.
you should implement some handsahe between reciver and transmitter the buffer i'm using is 64bytes so the transmiter will not send more then 64 bytes until the reciver didn't signal that it can read more bytes
