21 years agoCommon FLASH Interface
The FLASH devices used in my NIOS II system are not in the pull down menu of supported devices. The INTEL TE28F320J3A-110 (WORD Mode) is the closest. I'm using the TE28F256-xxx (WORD Mode...
21 years agogmm50,
You should not need to change the software if the device is CFI compliant, the CPU interrogates the device to find out how to program it. There was however a problem with using 16 bit devices in 8 bit mode which is fixed in the 1.01 release.
