15 years agoCombining Assembly and C
Hi, I am very new to Hardware Programming, and I am using the NIOS II processor to identify the frequency of a sound that is input into the DE1 Board. My question is, is it possible to combine...
15 years agoUsually such operations can be done in C.
For actual assembler either write an assembler source file containing C callable code (I think the Altera makefile will put a .S file through cpp and then gas), or use the gcc 'asm' statement to include the required instructions - these will tie C variables to registers as required. There should be some exampler lurking in the .h files or more generally on the web. NB: if you access any memory locations that C variables also access, then add a "memory" qualifier to the asm statement - otherwise gcc might optimise out the C code.
