12 years agoCode not running unless NIOS toolset attached
Hi, my system is a Cyclone 3 FPGA with external SDRAM for memory, with a EPCS64 attached for configuration and code storage. I am programming via a JTAG attached byteBlaster. I can ...
12 years agoCheck if Nios reset address matches EPCS base address.
Also check if you are using the correct EPCS boot loader. When you boot from jtag, can your code access EPCS?
