12 years agoCode not running unless NIOS toolset attached
Hi, my system is a Cyclone 3 FPGA with external SDRAM for memory, with a EPCS64 attached for configuration and code storage. I am programming via a JTAG attached byteBlaster. I can ...
12 years agoAll this has worked before. I am updating the toolsets from using Quartus 9.1. This has not been easy.
I am sure all the hardware works. Using 9.1 I can program the EPCS etiher through JTAG or using active serial and the code runs. Using 13.1 I can program the EPCS etiher through JTAG or using active serial and the code doesn't run. I guess I'm missing something in the BSP setup - but where ?
