16 years agoCode in tightly coupled memory
Hi all, I placed a function in a section different from the main code. More exactly, my code is mapped to sdram and I linked a function testcall() into a tightly coupled memory section which I pr...
16 years agoOk, now I know how to address tc_data, thanks.
But I intend to use TCM for ISRs (Interrupt Service Routine). I need to know, how to define an "Separate Hardware Interrupt Stack". I haven't found any examples. Better I explain my intentions in more detail. My ISR looks like this: static void handle_CPU2_interrupts(void* context, alt_u32 id) __attribute__ ((section (".exceptions"))); static void handle_CPU2_interrupts(void* context, alt_u32 id) { OSSemPost(IRQSem); // <-- benefit from a seperated exception stack ? IOWR_ALTERA_AVALON_PIO_EDGE_CAP(CPU1_INTHAND_BASE, 0x1); } void task(void* pdata) { [... init ...] while (1) { OSSemPend(IRQSem, 0, &err); <-- event waiting [ ... do something ... ] } } SoPC: I set the exception address, on the Core Nios II tab, in the Exception Vector: Memory: list, to tightly_coupled_instruction_memory_s1. RTOS: I use µC/OS-II. Problems: 1. ISR response takes ~16 µs. 2. From OSSemPost, in the ISR, to OSSemPend, in task, it takes ~34 µs. Any chances to reduce these times ? My possible solutions: -> Try TCM -> Try VIC -> will reduce ISR response certainly (<<16µs) If I had examples I wouldn't struggle with TCM and I can test possible performance improvements. I would appreciate any comments / suggestions. I need this for my bachelor thesis. Thanks any help very much. Regards, R2-D2 @chris72your thread "timer interrupt with rtos-ii"
similar to my project.
