20 years agoCode for handling a simple ISR
I made my file system, kernel, app and uploaded, this is the source:
# include "D:\Proyectos\Marzo\NIOS2ndTry\Krl\build\include\nios2_system.h"# include <stdio.h> typedef unsigned char INT8U;# define NIOSTmr (np_timer *)na_high_res_timer # define pio ((np_pio *)na_led_pio)# define PIO pio->np_piodata void TmrISR(void); int main(void) { (*NIOSTmr).np_timerperiodl = 0xB400; (*NIOSTmr).np_timerperiodh = 0x04C4; (*NIOSTmr).np_timercontrol = np_timercontrol_cont_mask | np_timercontrol_start_mask | np_timercontrol_ito_mask ; nr_installuserisr(na_high_res_timer_irq, &TmrISR, 0); while(1) { } return 0; } void TmrISR(void) { static INT8U Ctr; (*NIOSTmr).np_timerstatus &= ~np_timerstatus_to_mask; PIO = Ctr++; printf("%d seconds\n", Ctr); } but when i make my application, and try to run it, the system resets itself. Any suggestions, corrections of the malfunctioning?2 Replies
You can not use altera hal for interrupt service in uClinux. Read ch10 Interrupt Handling on the book "Linux device drivers 3rd ed.".
you are tryin to implement ISRs in a user-land application, and as far as I know, I don't think you can do this. All interrupts must be built into the kernel as a driver, correct? you need to write an actual driver, not a user application.
