19 years agoCode fails without "reduced device drivers"
I'm compiling a simple "hello world" app with the NIOS EDS v6.0 for a NIOS II V6.0 system running on a custom board. This system seems to run correctly (I even have GERMS running so I can manual...
16 years agoI think you should select proper UART device in run/debug options, target connection. In the field 'Nios II Terminal communication device' select your UART peripheral.
