16 years agoclock edge help!
hi everybody!
I'm working in modelsim verilog for 2weeks now, and i need some help. i used before to work on vhdl which functions as verilog. what i want to do is an adder (x+y=z ) with a call system to a C code and check the result with the hardware one. (it's called transaction based verification) i already do it and it perfectly functions . the next step for me where i found some problems is to make the adder functions on clock edge. here's what i did : module Add_Hard( clock, x, y, z ); input clock; input[7:0] x; input[7:0] y; output[8:0] z; //wire[7:0] x; //wire[7:0] y; reg[8:0] z; //declared as register because the value changes //during the always process wire[8:0] res; reg clock; initial clock=1; assign res=x+y ; initial begin clock=1; end always @(clock) begin z = res; //z_hard end endmodule // End of Module Add_hard //test bench module Add_vpi_tb_clock(); reg clock; reg[7:0] x1; reg[7:0] y1; wire[8:0] z_hard; reg[8:0] z_soft; reg[8:0] INT_z_hard; Add_Hard inst_Add( .clock(clock), .x(x1), .y(y1), .z(z_hard) //z_hard output ); //always# 1 clock = ! clock; initial begin clock=1; @(posedge clock) $display("clock:%d",clock); x1= $random; y1= $random; $Add_vpi(x1,y1,z_soft); assign INT_z_hard = z_hard; $Display_compare(INT_z_hard); # 100 $finish; end always# 2 clock = !clock; endmodule could any one help me doing the clock functionnality. thks all2 Replies
Please check your module Add_Hard . Inside it you are declared clock as input but you assign a value
initial clock=1; please remove this statement & try again - Altera_Forum
yeah! i alrready chane it but it did not work.... i did it differently and it works now:)!! it has been one day that i'm fightin with that !!!
thanks anyway
