20 years agochmod 777 /home/w/uClinux-dist-test/romfs/tmp
Hi all,
I am folling http://nioswiki.jot.com/wikihome/operating...ems/uclinuxdist (http://nioswiki.jot.com/wikihome/operatingsystems/uclinuxdist) to make boa,but I met the err message when I 'make': make[1]: Entering directory `/home/w/uClinux-dist-test/vendors' make -C /home/w/uClinux-dist-test/vendors/Altera/nios2nommu/. dir_v=/home/w/uClinux-dist-test/vendors/Altera/nios2nommu/. -f /home/w/uClinux-dist-test/vendors/vendors-common.mak romfs make[2]: Entering directory `/home/w/uClinux-dist-test/vendors/Altera/nios2nommu' [ -d /home/w/uClinux-dist-test/romfs/$i ] || mkdir -p /home/w/uClinux-dist-test/romfs for i in bin dev etc etc/dhcpc home lib mnt proc sys usr var root home tmp home/httpd home/httpd/cgi-bin etc/boa /etc/config var/run var/lib/misc var/log/boa; do [ -d /home/w/uClinux-dist-test/romfs/$i ] || mkdir -p /home/w/uClinux-dist-test/romfs/$i; done chmod 777 /home/w/uClinux-dist-test/romfs/tmp chmod: 正在更改 ‘/home/w/uClinux-dist-test/romfs/tmp’ 的权限: 不允许的操作 make[2]: *** [romfs] Error 1 make[2]: Leaving directory `/home/w/uClinux-dist-test/vendors/Altera/nios2nommu' make[1]: *** [romfs] Error 2 make[1]: Leaving directory `/home/w/uClinux-dist-test/vendors' make: *** [romfs.subdirs] Error 1 Who can tell me why?Thanks a lot!3 Replies
the prompt is very clearly, you have no enoph right to change the file' right. you can use the "su" command,change to root.the you can do it. - Altera_Forum
--- Quote Start --- originally posted by smalllight@Aug 25 2006, 05:50 PM chmod: 正在更改 ‘/home/w/uclinux-dist-test/romfs/tmp’ 的权限: 不允许的操作the prompt is very clearly, you have no enoph right to change the file' right.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=17830)
--- quote end ---
--- Quote End --- Thank you for your reply!smalllight. Do you mean that I should have to change makefile befor I "make"? I know how to change to root with command "su",but do not know how to change makefile.
--- Quote Start --- originally posted by wangzhiwunpu+aug 28 2006, 08:25 am--><div class='quotetop'>quote (wangzhiwunpu @ aug 28 2006, 08:25 am)</div>--- quote start ---
<!--quotebegin-smalllight@Aug 25 2006, 05:50 PM chmod: 正在更改 ‘/home/w/uclinux-dist-test/romfs/tmp’ 的权限: 不允许的操作
--- quote end ---
--- Quote End --- Thank you for your reply!smalllight. Do you mean that I should have to change makefile befor I "make"? I know how to change to root with command "su",but do not know how to change makefile. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17900)</div> [/b] --- Quote End --- yon don't have to change you make file, if you have a root right,there are no errror when you run the command chmod.so you only need change to root user then make.thats all
