17 years agoChanging the Size of Data and Instruction Cache
Hello again, I am trying to increase the data and instruction cache to test if the speed increases when reading data from the UART. At first, I tried making it four times bigger, Quartus said ...
17 years agoHello again halfdome, and everyone
So I've checked the drivers on the kernel config. Audio Support as well as video support were already disabled. On the Quartus project, I eliminated an Audio PLL because it wasn't being used anymore. Still getting the same results. With 4K Instruction and 2K Data Cache Memories(original settings), it works normally, however, when changing to bigger sizes, it doesn't work. what board are you using? I am using a DE2. And also, when you modify to increase the cache size, do you do steps other than recompiling? Perhaps some obvious steps but since I had never done this I am not doing them. Thanks
