17 years agoChanging the Size of Data and Instruction Cache
Hello again, I am trying to increase the data and instruction cache to test if the speed increases when reading data from the UART. At first, I tried making it four times bigger, Quartus said ...
17 years agoOk, I'm totally guessing now, but are you sure removed all references to the VGA and audio modules from the design? Also, if you have not done so already, it may be worthwhile to disable those drivers in the kernel configuration too. Good luck,
