17 years agoChanging the Size of Data and Instruction Cache
Hello again, I am trying to increase the data and instruction cache to test if the speed increases when reading data from the UART. At first, I tried making it four times bigger, Quartus said ...
17 years ago<div class='quotetop'>QUOTE (jasinski @ Jul 14 2009, 07:33 AM) <{post_snapback}> (index.php?act=findpost&pid=23102)</div>
--- Quote Start --- Did you check whether any peripheral had its base address/IRQ changed in SoPC Builder? if so, did you run make vendor_hwselect again? I don't know if this would be necessary, but it is one of the first things I'd try. Good luck, Ricardo.[/b] --- Quote End --- Hello Ricardo, Thank you. Yes, In order to make space for a greater cache (it uses more M4K blocks), I eliminated the VGA module and the Audio Module. Then: - Automatically reassigned the base Addresses in SOPC - Regenerated the system, and took out the corresponding pins in the top level. - Recompiled the project - Run vendor_hwselect Still nothing. I'll check if there is an extra PLL for the audio or VGA that I missed just to make sure it is not there. Francisco
