17 years agoChanging the Size of Data and Instruction Cache
Hello again, I am trying to increase the data and instruction cache to test if the speed increases when reading data from the UART. At first, I tried making it four times bigger, Quartus said ...
17 years agoHello halfdome,
Thanks for your fast answer. My configuration is the following on SOPC Builder when editing the Nios II Processor. Reset Vector= Memory: cfi_flash_0 Offset 0x0 Exception Vector= Memory sdram_0 Offset 0x20 Instruction Cache 4 KBytes Data Cache 2 KBytes Data Cache Line Size 4 Bytes Bursts Disabled Tightly Coupled master ports disabled. Like this, it works correctly. And then I only change the size of either Cache Memories. Regenerate the system, Recompile the project. After that: Make vendor_hwselect Make romfs Make and then try to run the OS, and nothing. Perhaps I am missing a step? Your help is greatly appreciated. Regards, Francisco News: I've made more tests and apparently it starts to boot. It starts to show all the messages that correspond to the normal boot. However, it stops at some point. It is never the same. Sometimes at the USB messages, others at the Ethernet messages. But it never reaches the console. There is also one message after "Shell invoked to run file /etc/rc" that says Reading Command line: Innapropiate ioctl for device
